Old 12-02-2014   #11
Re: Wanted, garage heat!
Gas line is super easy now, use the flexible stainless stuff. I just ran a line 55' and it took me an hour to do it. CSST is what they call it and Menards has the better stuff. Should only need a 1/2" line run to it. I scored a 30k BTU heater on CL for $35 to supplement the in floor heat. All hooked up and heating for $150 total.
Hmm. I may investigate this option. I may just mount the heater, run this kind of line, and then see how I feel about the last connection to the houses gas line.
What's used to seal the connections? Would I be shutting down the entire houses gas supply to do this or just the section I'm working on?
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
