Old 04-04-2015   #10
1990GSX
Drives: 1975 corvette stingray, 2008 evo x gsr
Re: Over Boosting? Need some help guys
To rule out boost creep, you could unhook the wastegate flapper so it's open all the time, and see what your max boost at redline is.
Did you try this yet? If it still creeping that means your not able to vent off enough exhaust fumes through the wastegate exit to keep the compressor from still building boost.
This would eliminate both the mbc as the source and the wastegate.
1990GSX is offline   Reply With Quote
Tags
all the boosts!
