Old 03-16-2017   #11
Re: Project Corvette
Hurry up spring!
New rear NTO5r's came already. Thanks Pat for the coupon deal! Went a step taller (305/35/19), because the old tires were 30 series and they looked too narrow compared to the fronts (285/35/18). The ratio is a bit larger, so hopefully no active handling issues pop up. They are almost the same size right now and it should have been causing errors already. Ill probably drop the car down a half inch or so this spring as well, so its not riding so high.
Hoping to get in the garage this weekend if its nice enough, need to change motor oil, trans and diff fluids as well as get the new alternator in. No real rush as winter is still crappily hanging on.
Tags
stanceboi, wind in da grey bush!
