Old 03-24-2017   #1
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
EvoTuna's Tax Season Partout #2
Evo 8/9 Multiple Evo Partout:
EVERYTHING IS IN GOOD-GREAT WORKING CONDITION UNLESS STATED OTHERWISE. Texting is the best way to get ahold of me, email and pms will take me longer to get to.
-I'm located in Mankato MN. If it’s not listed I more than likely don’t have it.
-Phone # 507-215-2103. Texting is preferred.
Thanks
Chris
ENGINE:
-Evo 9 Built 2.0 TSCOMP Built, Manley Turbo Tuff Rods, Wiseco Pistons, Curt Brown Ported Head, GSC S3s and Valve Springs, Ferrea Valves (2k miles) - PENDING
-Evo 9 Built 2.4 Longblock By English Racing (Carillo Rods, Wiseco Pistons, Eagle Billet Crank, Moroso Oil Pan. GSC R2 Cams/Valvetrain. 10k miles) - $5500 shipped
-STM Sealed Oil Catch Can Brushed Aluminum and STM 3.5" Vented Intake Pipe Polished for STM Sealed Catch Can (http://www.streettunedmotorsports.co...ch_can_new.htm and http://www.streettunedmotorsports.co..._catchcan.htm- $600 shipped
-Hallman Pro MBC (Black) - $70 shipped
-Aluminum “Evolution” Spark Plug Cover with Hardware - $110 shipped
-CF Spark Plug Cover Evo 8 - $70 shipped
TRANS/CLUTCHES/TCASE/DIFF/DIFF PARTS/AXLES/ACD PUMPS:
-Evo ACD Tcase 82xxx miles - $1150 shipped
-Evo 8/9 Rear Diff with Billet Frontline Fab Diff Cover and Torque Solutions Solid Mount Kit (82k miles) - $1000 shipped
-OEM Front Axles - $280 shipped for a set or $140 each
-OEM Rear Axles - $280 shipped for a set or $140 each
-Quartermaster 8 Leg Race Clutch (Discs at .225-.245) Comes with Hydraulic TOB - $1000 shipped
-Buschur Racing Shifter Base Bushings - $20 shipped
-Braided Clutch Line Full Line - $40 shipped
-(2) Braided Clutch Line (Half Line) - $20 shipped
TURBOS/WASTEGATES/FMIC/PIPING/MINI BATTERY/RADIATOR/COOLING:
-FP Black Ball Bearing with Red Tial Wastegate and Oil Line (EVERYTHING IS BRAND NEW) - $2300 shipped
-Garret HTA 3586 Ball Bearing, Buschur VBand Manifold, Tial Wastegates/Dump Tubes and VBand Downpipe and Intake (Very good shape) - $2750 shipped
-Evo 8 9.8 Turbo Comes with Wastegate/Lines/OEM Exhaust Manifold/Megan O2 Housing (Perfect shape) - $350 shipped
-AMS UICP (Stock BOV) Great shape - $240 shipped
-Mini Battery Tray - $70 shipped
-ETS Mini Battery - $80 shipped
-Mishimoto Radiator with Slim Fan (Perfect shape) - $240 shipped
-Megan Racing Radiator with Slim Fan - $160 shipped
-OEM Radiator with Slim Fan and Shroud - $160 shipped
-Samco Radiator Hoses Blue (4/5/6) BRAND NEW - $100 shipped
EXHAUST/INTAKE MANIFOLDS/INATKES/BOVS/MAFs:
-(2) Invidia O2 housing - $140 shipped
-OEM Turboback Exhaust - $150 picked up
-Aftermarket Straight Pipe Exhaust (test pipe back, no downpipe) with Perrin test pipe welded to it - $80 picked up
-Aftermarket Stock Turbo Intake - $30 shipped
-Aluminum Heat Shield (Custom, fits OEM manifolds or FP manifold) - $40 shipped
IGNITON/FUEL PUMPS/INJECTORS/RAILS:
-JMF Billet COP with Dynatek ARC-2 CDI Box - $600 shipped
-Areomotive Fuel Rail - $150 shipped
-Magnecor Ignition Cables - $60 shipped
-(2) Walbro 255 - $50 shipped
GAUGES/ECUS/RADIOS/ELECTRONICS/OEM ELECTRONICS:
-AEM Spec Ops Serial Cable BRAND NEW - $25 shipped
-E85 Flex Fuel Sensor - $80 shipped
-OEM Gauge Cluster (100k miles) - $120 shipped
-Apexi Turbo Timer and Evo Specific Harness - $50 shipped
-Alpine Radio (CDE 110) - $40 shipped
-Polk Front Door Speakers (60 RMS, 180 Peak, 4 OHMs) - $40 shipped
-Foval 300W Power Inverter - $25 shipped
SUSPENSION/BRAKES/WHEELS AND TIRES/BRACES/AFTERMARKET AND OEM:
-Rota Torques (Light Silver, LIKE NEW) with NT555 245/45/17 (500 miles on them, willing to split wheels and tires) - $1600
-Rotor Pros Front and Rear Rotors - $200 picked up
-Ichiba 10MM and 5MM Wheel Spacers (All 4, BRAND NEW) - $160 shipped
-Whiteline Rear Sway Bar BRAND NEW - $140 picked up
-Whiteline 24MM Rear Sway Bar (8k miles) $120 picked up
-OEM Front Control Arms with Whiteline Bushings and Tie Rod Ends - $350 shipped
-OEM Front Control Arms – $120 shipped each
-OEM Rear Control Arms – PM with what ones you need, have three sets worth
-(2) OEM Front Sway Bar - $80 shipped
-OEM Rear Sway Bar - $80 shipped
-(1 set) Front Knuckles - $120 shipped
-(2 sets) Rear Knuckles - $120 shipped
-(2) Rear Subframe - $150 shipped
-Mustache Bar OEM - $100 shipped
-Power Steering Rack - $150 shipped
-(3 sets) OEM Chassis Braces - OFFER
-(3) OEM Front Strut Bars – OFFER
-(3) Steering Columns with Ignition Switch/Key - $80 shipped each
-(3) Front Rotor Shields - $30 shipped
OEM INTERIOR/SEATS/CONSOLES/TRIM:
-Evo 8 Blue Recaro Pass Front Seat - $150 picked up
-Evo 9 Rear Seat Sound Deadening Mat - $40 shipped
-Evo 8 Steering Wheel (No Airbag) - $160 shipped
-Evo 8/9 Trunk Interior - $100 picked up
-OEM Blue Weighted Shift Knob BRAND NEW - $80 shipped
-Evo 8/9 Double Din Dash Piece - $100 shipped
-Autometer 3 Gauge Pod in OEM Radio/Climate Control Dash Piece - $35 shipped
-(3) Steering Wheel Single Gauge Pod Holder - $30 shipped
-A Pillar Single Gauge Pod (BLACK) - $15 shipped
-(2) Steering Wheel Cover $20 shipped
-(2) Lower Cubby for MR/RS Gauges - $40 shipped
-(2) Glovebox - $40 shipped
-(3) Gauge Cluster Bezel - $25 shipped
-(2) Dimmer Switch - $15 shipped
-Mirror Control Switch - $15 shipped
-Cigarette Lighter - $10 shipped
-Sun Visor (Passenger Side) - $30 shipped
-Heater Core - $160 shipped
-Evo 8/9 Interior Pieces (I have a few cars worth) - PM what you need
OEM/AFTERMARKET EXTERIOR PARTS:
-Evo 8/9 APR Front Bumper Canards (One has a little damage) - $75 shipped
-Evo 8 Apex Silver Driver Front Door - $300 picked up
-Evo 8 Apex Silver Driver Side Rear Door (Bend on bottom corner, very small) - $100 picked up
-Evo 9 WW Driver Front Door - $300 picked up
-Evo 9 WW Driver Side Rear Door - $300 picked up
-Evo 9 WW Wingless Trunk Lid (Perfect shape just painted a year ago. No Holes) - $400 picked up
-Evo 9 OEM Front Bumper Brackets/Mesh and Vents - $250 shipped
-Evo 9 Front Bumper Lip BRAND NEW (ebay poly) $50 picked up
-Rear Bumper License Plate Bracket and Wiring - $100 shipped
-Evo 8/9 Apex Silver Hood Flanges By Strut Towers - $50 shipped
-Evo 8 Tail Lights (With bulbs and wiring) - $100 shipped
-Evo 8 Tail Lights (No bulbs or wiring) - $60 shipped
-Winshield Wiper Cowls Driver and Pass - $100 shipped
-(8) Clear Side Markers - $8 for a set
-Apex Silver Gas Door with Cap - $50 shipped
-Hood Latch - $35 shipped
-(2) OEM Gas Cap - $15 shipped
-Under Hood Fuse Box Cover - $20 shipped
-Evo 8 Bumper Mesh/Vents – PM what you need
Evo 8/9 OEM PARTS
SENSORS:
-Crank Sensor - $60 shipped
-Exhaust Cam Sensor - $30 shipped
-(3) Knock Sensor - $50 shipped
-(2) Evo (03-04) MAP Sensors - $40 shipped
-(2) Evo (05-06) MAP Sensors - $40 shipped
-(3) Oil Pressure Switches - $15 shipped
-(4) Impact Sensors (Core Support) - $50 shipped
-(2) Airbag Impact Sensor (Inside Car) - $50 shipped
TIMING:
-Box of Like New Timing Components – PM Me
-Evo 9 Gates Timing Belt (10k miles) - $60 shipped
-AC Delete Serpentine Belts - $25 shipped
-(2) LIKE NEW OEM Evo 8 Water Pump (Idle time only) - $80 shipped or best offer
-(3) OEM Serpentine Belt Tensioner - $70 shipped
-(3) OEM Crank Pulley - $60 shipped
-(3) OEM Serp Belt Idler - $30 shipped
OEM EXAUST MANIFOLDS/O2 HOUSINGS/INTAKE MANIFOLDS/THROTTLE BODY:
-(3) OEM Driveshaft in very nice shape - $130 shipped
-OEM Exhaust Manifold - $70 shipped
-(4) OEM Intake Manifold - $75 shipped (Three have EGR still and MAP Sensor)
-DSM BOV - $30 shipped
STARTER/ALTERNATOR/WIREHARNESSES/POWER STEERING PUMPS/AC COMPRESSORS:
-(1) OEM Alternator - $90 shipped
-(4) OEM Starter - $90 shipped
-Evo 9 Engine Wire Harness - $300 shipped
-Evo 8 Engine Wire Harness - $220 shipped
-Evo 8 Alternator Harness - $70 shipped
-(2) Evo 9 Alternator Harness - $70 shipped
OEM ENGINE PARTS/BRACKETS/ENGINE BAY PARTS:
-Evo 8/9 Rockers – $200 shipped per set
-Evo 8 Oil Filter Housings - $80 shipped
-(4) OEM Cam Gears - OFFER
-OEM Evo 8 Cams – OFFER
-OEM Valve Springs - $40 shipped
-(3) MIVEC Oil Line - $20 shipped
-(3) Oil Dipstick with Tube - $30 shipped
-OEM Motor Mounts (5 Side Engine Mounts, 2 Rear Mounts) – OFFER
-(4) Motor Mount Bracket to Block - $80 shipped
-Brake Booster - $80 shipped
- (3) Master Cylinder - $80 shipped
-Clutch Master Cylinder- $60 shipped
-(3) OEM Clutch Slave - $50 shipped
-(3) Evo 8 Coolant Hard Pipe - $40 shipped
-Evo 9 Coolant Hard Pipe and Thermostat/Sensors - $100 shipped
-(2) Evo 9 Coolant Hard Pipe - $40 shipped
-Evo 8/9 Thermostat Housings with Sensors - $60 shipped
-(6) Block to Trans Shield with Starter Hole – $30 shipped
-Flywheel Shields (Under block, bolts into trans) - $25 shipped
-(7) AC Compressor Bracket - $25 shipped
-(3) Coolant Reservoir - $25 shipped
-(2) Power Steering Reservoir - $25 shipped
-Power Steering Cooler Line - $120 shipped
-(2) Hood Prop - $20 shipped
-(2) Front Windshield Wiper Motor - $30 shipped
-ABS Module – OFFER
-Evo 8/9 Injector Resistor Pack/Bracket - $40 shipped
-Evo 8 OEM Spark Plug Cover - $20 shipped
-(3) Evo 8/9 Horns - $10 shipped
OEM IGNITION/FUEL/RADIATORS/FANS/PIPING/MODULES/AC LINES:
-OEM Fuel Tank (Southern car, tank is perfect) - $150 picked up
-OEM Evo 8/9 Ignition Coils - $70 shipped
-(2) OEM Fuel Rail/FPR - $45 shipped
-(2) OEM Fuel Rail - $30 shipped
-OEM Radiator - $120 shipped
-Radiator Fan/Shroud/Module - $90 shipped
-Radiator Fan/Shroud no Module - $70 shipped
-Radiator Fan Module - $40 shipped
-(2) AC Condenser Fans (Have one single fan if interested) - $60 shipped
-(5) OEM Upper Radiator Pipes - $20 shipped
-(10) OEM Lower Radiator Pipes - $20 shipped
-(6 sets) OEM Radiator Upper Mounts – $15 shipped per set
-Tons of AC Lines (Lmk what you need) - OFFER
SOLD:
-Evo 8/9 OEM Oil Pan
-Evo 8/9 2.0 Crankshaft
-STM Oil Cooler with Lines
-Grimmspeed EBC
-Evo NON ACD Tcase 100xxx miles
-Torque Solutions Mustache Bar Delete Kit
-Frontline Fab Rear Diff Cover BRAND NEWW
-AMS 3.5” FMIC Great Shape
-Koyo Small Radiator with Slim Fan
-Curt Brown Ported Throttle Body (No Sensors)
-Buschur Test Pipe Back Exhaust (Slip fitting not flanged)
-Megan Racing High Flow Cat
-ID2000s with PnP Adapters/Resistor Box Bypass Plug (2k miles on Pump Gas)
-Boostin Performance Fuel Rail with 6AN Fittings
-Fuel Lab FPR with Lines
-Evo 9 ECU
-LIKE NEW Volk RE30, 18x9 +35 with Toyo 265/35/18 (Wheels and Tires only have a few hundred miles)
-PlastiDip Kit for 4 Wheels (One extra can of black as well) ALL BRAND NEW
-Evo 9 Steering Wheel (With Airbag)
-Evo 9 MR Pedals
-OEM Center Console (05-06 no sprayer switch)
-OEM Radio and Climate Control Dash Piece
-OEM O2 Housing with O2 Sensor
-Evo 8 Coolant Hard Pipe and Thermostat/Sensors
-Power Steering Pump Bracket (Has crack in bolt hole, still bolts up, nothing crazy)
-Evo 8 Stock Shortblock (Freshly Machined to .020 over PM for more details)
-OMNI 4Bar MAP Sensor (Has gay ass barbed fitting on backside because people are cheap and dumb as fuck)
-ARP Standard Headstuds
-Evo ACD Tcase 100xxx miles
-Driveshaft Shop Carbon Fiber Driveshaft (1k miles)
-Exedy Triple Disc Clutch (2k miles, discs measured at 3.80-3.90mm)
-5speed Shifter Cables and Shifter Base with Aftermarket Bushings
-FP Zero Ball Bearing with Install Kit with Vband O2 Housing/Downpipe (2k miles)
-Tial MV-S Wastegate (Brand New and Silver in color)
-Curt Brown Ported Intake Manifold
-Boostin Performance Ported Throttle Body
-Velocity Wheels (LIKE NEW with Blue Blox Lugnuts). Sentury Tires 225/40/18 (1000 miles on them)
-Brembo Calipers Front and Rear (Coated a bronze color, good pads and very nice shape)
-Ultra Racing Front Strut Bar (White in Color)
-Ultra Racing Rear Strut Bar (White in Color)
-OEM Aluminum Front Strut Bar (RED) BRAND NEW
-Front Subframe
-Evo 8/9 VIS Demon Carbon Fiber Trunk (BRAND NEW)
-Rear Bumper Tarmac Black OEM
-JDM Rear Tow Hook Cover
-OEM Battery Tray (Missing top bracket)
-OEM Alternator
-OEM Starter
-OEM Driveshaft in very nice shape
-OEM Crank Pulley
-Custom Oil Catch Can with Lines - SOLD
-OMNI 7Bar MAP Sensor - SOLD
-TRE ACD Tcase (PM for more info and invoice) - SOLD
-Evo ACD Tcase 87xxx miles - SOLD
-(2) OEM Flywheels - SOLD
-Fidanza Flywheel - SOLD
-MAP O2 Housing - SOLD
-OEM Evo 9 Gauge Cluster (100xxx miles) with AEM A/F Digital Gauge in “Lancer Spot” and aftermarket color scheme on cluster. Also includes Prosport Gauges and Triple Dash Gauge Pod (Fuel Pressure/Oil Pressure/Boost) - SOLD
-AEM Digital A/F Gauge (Black Bezel/Face and BRAND NEW O2 Sensor) - SOLD
-Autometer “Sport Comp” Boost Gauge (45psi) - SOLD
-Kenwood KDC-BT555U with Remote - SOLD
-Rear Diff Aluminum Chassis Mount – SOLD
-Power Steering Rack – SOLD
-Shorty Antenna - SOLD
-(3) Power Steering Pump without Pulleys - SOLD
-Evo 8 Engine Wire Harness - SOLD
-Evo 9 Thermostat/Sensors - SOLD
-ABS Module - SOLD
2006 WW IX RS 396/404 - SOLD
