Old 04-07-2017   #11
Re: Project Lex
So while waiting for all the tires to arrive, and for the wheels to get refinished with proline finish, I decided to knock out some other things.
- Installed braided brake lines that I've have sitting here for a couple years now. Went ahead and got the rotors turned while I was at it and flushed the fluid with new DOT4 fluid. Also gave the NA Supra rear calipers a coat of black paint to clean em up a bit and match the fronts.
- Got my new distributor cover design back from Shawn who 3D printed it for me. Fits good except for the ID of the outter portion is about 1mm too tight. So I hand to sand it down and it fits perfect. So I'll be updating the Solidworks model and should be good to go for others to 3D print on their own now.
- Got my two AEM 12 position switches wired into Infinity. One will be for in car boost adjustment. Other for in car traction control adjustment.
- Also got my gauge / switch DIN mount back from Shawn as well who 3D printed it. Haven't fully test fit everything but so far so good, just had to do a little sanding but that's it so far. Once I've verified all fitment I will probably put some sort of vinyl over the front to give it a nice clean finished look.
- Started working on replacing the ABS sensors and then will be wiring them into the Infinity for traction control to function. Plan will also be to use those for a speed signal to the ecu so I can do other cool stuff like boost by mph and what not.
ID:	16459   Click image for larger version
ID:	16460   Click image for larger version
ID:	16462   Click image for larger version
ID:	16463   Click image for larger version
