Old 07-31-2004   #7
illz
if you mean keep handling, as in you think your sportlines are improving handling, they arent. more suspension travel = better handling. except when there is extreme travel to begin with, the lower center of gravity does not give you nearly the gains in handling to overcome the losses from very little travel. hopefully you have shocks to accompany your springs, regardless if they are sportlines or pro kits, as the stock dampers can't adequately control the increased rate.
