Old 11-11-2003   #8
we did use a straight edge, put cyl #1 at TDC, alligned cam gears, both dowels pointing north, alligned the front balance shaft sprocket thing to the timing mark, made sure the oil pump sprocket was alligned correctly and not 360 degrees off. Nothing more to allign that im aware of. so bent valves is what im thinkin
