Old 08-17-2004   #11
Well here's the maintenance record the current owner has...
Date Purchased Date Finished Mileage Item(s)
07/01/02 07/01/02 78000 Bought Laser
07/10/02 07/10/02 78799 Dealer Inspection
07/26/02 08/03/02 78843 Wiper Blades
07/26/02 08/03/02 78843 Valve Cover Gasket
07/26/02 08/03/02 78843 PCV Valve
07/26/02 08/03/02 78843 Hatch Supports
07/25/02 08/03/02 78843 Spark Plugs
07/25/02 08/03/02 78843 Magnecore Spark Plug Wires
08/14/02 08/14/02 78865 Transfer Case Recall
08/27/02 08/27/02 78882 New Timing Belt
10/09/02 10/09/02 79146 New Clutch, CV boots, Throttle body service
10/04/02 10/09/02 79146 Rebuilt Transmission
10/31/02 10/31/02 79573 Two New Front Tires, Alignment, Balance
11/15/02 11/16/02 79773 Fuel Injector Insulators
10/28/02 11/16/02 79773 New/Cleaned Injectors
07/26/02 11/16/02 79773 Oil Restorer
07/26/02 11/16/02 79773 Oil Filter
07/25/02 11/16/02 79773 KN Filter
12/10/02 12/10/02 80012 Transmission Leaking, New Fuel Filter
12/17/02 12/17/02 80051 Battery for remote locks
02/18/03 02/18/03 83000 New Oil Pan Plug & New Battery Terminals
02/18/03 02/18/03 83000 New Alternator
01/11/03 02/18/03 83000 MAS Replaced and Modified
05/23/03 05/23/03 84610 O2 sensor, Oil Pressure sensor, Inspection
05/28/03 07/11/03 85443 New Fuel Pump
08/06/03 08/06/03 85885 New Brakes, Sway Bar Link Ends
01/30/04 01/30/04 89000 Two New Front Tires, Balance
He also has the following parts which I bet I could get him to include the majority with the deal:
intake manifold.  very clean.
fuel rail
black top injectors (not sure what size those are)
rear panel lights for an eclipse
fuel door
drivers side rear side light cover
23 spline transfer case
pink top injectors (not sure of size.  also not sure i still have these)
also have, 3 sets of blue top toyota injectors.  have the size at home.  but i konw that these are NOT the same as blue top DSM injectors (not 450ccs), but they should fit in a dsm engine.
have a kn filter cleaner kit and a tornado air flow system.
