Old 09-13-2004   #6
stikx
Mr -
it used to be hacked but not anymore i used the sample settings from RRE's page the 2g big16g 550s 255 3" DP and fmic 19psi because it was the closest setup to my car. Car now seems to run fine but my car is at 17.5 psi and it has no downpipe so in theory i am seeing less airflow than the car from RRE's page right? so if both cars were in similar conditions i would not lean my car as low as he did with the afc right? because 3k-4k on the car seems a bit weaker than it used to be but pulls harder after that. if you richen a HI point by 1% would u have to richen the Low Point at the same rpm by 1%?
Setup:
Big16g 17.5 psi
Fmic
550s
255 fuel pump
3" exhuast
