Old 09-23-2004   #1
john
Business as usual
john's Avatar
Didn't Joe remove your bcs at the dyno fest? Just remove the hose from the valve cover and block it off (the nipple on the intake) so you do not have a vaccum leak. Route the rest of the line to the ground or get a breather filter.
Remove the line from the stock intake and block off that line also. Pull the line off the intake pipe, pull the bcs out of the car, and block off the nipple on the T fitting. You could either block it off or get rid of the T and get a hose mender. Neither line serves a usefull purpose and they both can be removed easily from the intake pipe. Sounds like your "plans" are a intake pipe huh.
97 Viper GTS
