Old 09-25-2004   #4
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
I've found it helps to have a second person to help saw with you on the other side of the glass. Wear gloves, and make sure you don't put much pressure on the glass--it's most likely to crack on the edges. If you're getting glass from the junkyard, they often have glass cutting wire available to use.
