Old 10-16-2004   #21
john
Business as usual
john's Avatar
Originally posted by tsiawdspeed@Oct 16 2004, 09:25 AM
I think he was saying to check the compression now to see if the timing skipped a few teeth and smashed the valves.
Yep. You would want to remove the lower cover to see if those are aligned also. Does the car drive now? If it were me, instead of dicking with the wiring, I would pull a plug wire to see if it is getting spark. Then I would disconnect the fuel feed line for a second and see if it is sending fuel to the rail. If both of the above are fine, check timing.
97 Viper GTS
