Old 11-02-2004   #6
santa
Boost Spike
santa's Avatar
Its a folcrum ball! I dont understand why you would think that adjusting the clutch peddle wouldnt possibly help him out with his problem? I would start with a flush of the slave cyl. Get some new fluid and bleed the clutch. TRE's web site has a good description on how to bleed your slave cyl. If that doesn't work You could try the washer deal. It is a cheap was of fixing your problem but a pain in the a$$ to do because you have to pull the tranny out again. the exstended slave rod could fix your problem too. I would do all of those if bleeding the slave and adjusting the clutch rod under the dash. The other problem could also be worn syncro's or possibly a bent input shaft(I can't think of the proper name).
