Old 11-03-2004   #7
b00stingsx
Send a message via AIM to b00stingsx
ok i took the starter off, and the negative connection was loose. i cleaned off the grounds and it has been starting fine now.
I will go take out the ecu to see if it needs caps/and is eprom.
Another question. I was testing fuses under the dash, and only a few of them lighted up. The ones that didnt light up were still good fuses though, and the acc.'s that they run currently dont work. Example, Driver side automatic seatbelt doesnt work. but the fuse is not popped. hope the ecu is the problem, but if anyone else has any ideas, lmk.
b00stingsx is offline   Reply With Quote
