Old 11-17-2004   #19
The part that breaks off is only brazed to the banjo fitting, so to much heat, vibration, and/or contact from the crank would cause it to fall off easy enough. And unless the bolt falls out it will not lower your oil pressure, the check valve is in the bolt itself.
