Old 11-19-2004   #13
x1genx
x1genx's Avatar
Drives: 90 1g awd
Send a message via AIM to x1genx
pull the axles if you havent, i cant figure out if you have or not.....and then check that bolt that enes was talking about.....drop the transmission with someone underneath it to guide it down....pull the motor...just becareful of the flywheel/clutch and the dust shield...thats what i last did. It worked out well. I only had the car on jack stands as well...maybe 10 inches off the ground.....just make sure everything is free of everything before you start yanking.
x1genx is offline   Reply With Quote
