Old 12-03-2004   #1
Khadgar
Can't Actually Wrench
Send a message via AIM to Khadgar
Smell of fuel in car
Hey right now after doing my rail and AFPR I am noticing the smell of fuel in the car, but I do not see any leaks in the engine bay around the stuff I just put in, I also do not smell it in the engine bay..
I pulled my backseat and I noticed that the white ring was only finger tight from when I installed my 255 a few months ago.
Could it be this is causing the smell in the car, while I was driving I tried to air out the car by opening the sunroof to vent but this seemed to make it noticeably worse. This may be really far off but, does opening the sunroof lower the airpressure in the car? If it does, could it be that when I do that, the pressure difference between the car and tank increases and more fumes are pulled in with the pressures trying to equal out? Of course this would only be if is actually the pump thing in the trunk that is causing the smell, I will double check my feed and return lines and make sure to tighten the white ring up and I will see if it gets better or worse on the way back from work after it sits for while.
Khadgar is offline   Reply With Quote
