Old 12-19-2004   #7
Re: Question about shifter linkage
Well today I took my car to storage and it shifts so close to the floor you lift your foot a mm and your engaged haha. Reverse is an even more impossible bitch to get into. This spring I will bleed it out again with the adjustment rod all the way into the master cylinder (You should try this) and then readjust it to normal and see if that helps.
Im out of options, did the new fork, shimmed new ball, longer slave rod, welded pedal and Im almost out of adjustment.
