Old 01-08-2005   #2
Re: A few 6 bolt questions!
1. 6 bolt pistons should fit 6 bolt rods without any problems. There is only an issue when trying to run 2g pistons on 1g rods.
2. I think both the rod and pistons are good for about the same power levels. If one had to be stronger then the other, the piston would probably support more power than the rod would.
3. Forged rods only please.
4. Mains studs are not the norm for the 6 bolt engine. You can run them, but the block/mains have to be recut/machined for it to work correctly.
