Old 01-10-2005   #2
Re: Easiest way to get the springs/valves off head.
You need a tool that will compress the spring and retainer, but allow you to get the two clips out from in between the retainer and the valve stem. You will also need a way to keep the valve from moving as you compress the spring.
