Old 11-30-2003   #4
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
Or you could do it like we did on Terina's engine. About 2 months ago (or more) we did hers and it still looks like it rolled off the showroom floor.
First, after you've driven it for a little while (maybe a half an hour or so) bring it home (or the self serve car wash) and shut it off. Next, put some Simple Green into a spray bottle and spray the hell out of the engine while it is still warm (but not running). Squirt a little extra in those really greasy spots. Let it sit for about 10 minutes or so. Then get the garden hose out and hose it down. Warm water works the best but you can use cold as well. Hose down the engine to get all the stuff off. If you want to you cover your alternator, tps sensor, etc. you can but not always necessary when you use a garden hose as opposed to using a pressure washer.
After that's all done, let it sit for a while to dry. Once it's done, mix up a mixture of half Armor All and half water in another spray bottle. Spray it over the engine (try to avoid spraying directly into the alternator and such) and you're done. The Armor All mixture will give it a beautiful shine and will resist getting dirty. It also helps protect your hoses from the elements.
If you want to know how well it works, just ask Jana, Allan, Blake or anyone that was at the cookout that we had a while back. I think Allan still has some pics somewhere of it. It's easier than hell this way and it lasts for quite a long time.
