Old 01-28-2005   #4
slowHonduh
DSM Rapist
slowHonduh's Avatar
Re: Honda brakes
Yes the front rotors are pressed on. you either have to take out the entire steering knuckle and press them off. Or depending how stuck they are, you can also use a slide hammer(that you bolt onto the wheel studs). That has worked for me a few times. But other times i've had to actually press them off.
And 90% of the time you will ruin the bearings while doing this. But most of the time even if you fucked them up, just put them back in and they will still work. Mine have for 10k miles now.
That accord ;)
slowHonduh is offline   Reply With Quote
