Old 01-30-2005   #5
Re: "Hacking the MAF??"
Originally Posted by TGPilot
Well that is two against...anyone else who had a "good" experience with the 1g hack?
Yes, it can work well, but it takes a lot of fiddling, tuning and only hacking out the correct amount. If you plan on making 450whp or less, then just throw on a stock 2G MAS, they work perfect and don't require much tuning. If you plan on making more than that, then a hacked 1G MAS can work, but if your at that power, you should probably just do a MAFT or speed density setup anyways. If you aren't experiencing MAF overrun now, then you can just stick with your current setup for the time being.
