Old 03-05-2005   #6
SpicyOrange
Re: What are the symptoms of a broken balance shaft belt?
Originally Posted by Raptor
If the bearing on the rear balance shaft went, it could make some pretty nasty vibrations as well, should hear that pretty well if it were the case though.
So tell me more about this bearing? Is it common for it to go out? Is there any diagnosis to see if it is bad?
I did the Timing belt and balance shaft belt tonight and once I had it apart I knew it wasn't gonna fix anything. The motor has a pretty bad shake at idle, and you can feel it get noticably worse at 3500 rpms. I almost positive its in the motor. Pushing the clutch in has not affect on the vibration. It will vibrate while the car is standing still or moving at 60mph. Please help!
Nick
SpicyOrange is offline   Reply With Quote
