Old 03-23-2005   #15
LightningGSX
Hellbound
Re: Airbag Removal
Seriously, make sure the IGN is off and just unplug it already.It takes in excess of 9 volts to fire it.As soon as its disconnected, the shorting pin shorts out the terminals.This makes the shorting pin the path of least resistance in the circuit, and according to a 100+ years of science, that makes it impossible for current to flow to the detanator.If it makes you feel better, just get out of the way when you unplug it.And if you don't trust 100+ years of science, wear a wrist grounding strap when you remove the detanator from the airbag assembly
-Nulli Secundus-
