Old 04-16-2005   #10
Re: Clutch problems. I'm F****D! HELP!!!!!
Look at your pressure plate carefully and make sure that none of the fingers are sprung. I just had a similar problem with my car, turned that the clutch disk exploded and some of it got lodged in the pressure plate where I couldn't see it. Put it all back togethre and it wouldn't shift. Pulled it back out and could tell right away that the pressure plate what fucked. If you have another one lying around that is good put them side by side, sometimes the difference is hard to see.
CRAIG
