Old 04-23-2005   #8
LightningGSX
Hellbound
Re: Ceramic Turbines?
Originally Posted by Wizard
The ceramic is not only for lightweight, but the main advantage was the fact that not as much heat would be transfered into the turbo. The heat would stay in the exhaust. And if anyone knows the theory of exhaust velocity and heat transfer (read up on exhaust wrap) you would see the reasoning.
Wiz
I doubt very much heat is transfered into the turbo through the exhaust wheel, regardless of what material it's made of.Even if it did insulate somewhat, with the amount of heat conducted through the other parts it wouldn't even matter.Reduced mass is pretty much the only benefit of a ceramic turbine wheel
-Nulli Secundus-
