Old 05-21-2005   #2
Re: Rear O2 Sensor.. damn MN Roads!
Fix the wire and then unhook your battery for a minute or two which will reset your ECU and you should be fine. The CEL won't go away unless you have a logger to pull the code and reset it or two do what I said above.
CRAIG
