Old 05-21-2005   #3
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: Rear O2 Sensor.. damn MN Roads!
Originally Posted by CRAIG
Fix the wire and then unhook your battery for a minute or two which will reset your ECU and you should be fine. The CEL won't go away unless you have a logger to pull the code and reset it or two do what I said above.
CRAIG
do you have any idea where the wire welds to? I tried to look everywhere for the mount point but couldn't find it.
