Old 12-15-2003   #6
Auto's are 360cc injectors. I would get the Evo B16g for the little bit of extra money it is. People seem to really be having good luck with them. If I remember right you can just use your stock feed/return lines. The turbo is only off 1", so they can be bent. I am 95% sure this is what I did with mine. That was many years ago though.
The 5 spd ECU will work in the auto too. After you do those upgrades the only difference will be the cams.
