Old 06-09-2005   #11
LightningGSX
Hellbound
Re: High Knock in my Talon
Originally Posted by me612
Sorry I have not had internet access at my house since I got home until about an hour ago. OK I double checked the timing. All marks lined up, and timing is set right around 8-9 BTDC. As far as the SAFC, everything is set to 0 right now because I haven't put in any of the new parts yet. Steve maybe when you get my car, I'll drive the Talon there to pick it up and see if you see anything that I don't if you don't mind taking a peek at it. This is real annoying because I lose a ton of power when this happens. It seems like it's a problem right around the 3-4k range. Even if I am accellerating at a nice normal moderate rate, right when I hit around 3k rpms, it kinda bogs off and on until I'm over 4k and then I'll get most the power back. Thanks again for everyones help.
Your base timing is set to 8-9 Deg's?
-Nulli Secundus-
