Old 06-12-2005   #15
Re: boost leak
Well that explains alot more than what was written before. Still if you cant see any leaks on the TB then it must be the Intake manifold. Use a stethescope and try and listen where the hissing gets louder. Your vacuum should be around 18 unless that car has cams. That would have to be one giant boost leak to lower vacuum that much.
