Old 06-14-2005   #5
Re: Passenger window don't work
sorry, it's a 91 TSI. By master switch, are you refferring to the driver side switch? This problem actually semi appeared soon as I got home. The passenger side switch wouldn't work unless you kinda pushed on the arm rest where it is located. And then it would only work sometimes. But it always worked when I did it from the driver side. Now it just doesn't work on either of the switches. So are you saying try a known good switch on the driver side and see what happens? Thanks for the help so far.
