Old 06-16-2005   #8
Re: Need some tuning help from some of you Professionals.
With your mods you should not be knocking at that boost with a 50trim. Like stated above, put some decent gas in your car and see if that helps. My guess from listening to your post is that you have some bad/low quality gas. If that doesn't help then run some logs and see where its knocking and play with fuel and timing in that spot and see if you can get it to go away.
CRAIG
