Old 06-17-2005   #8
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Weird studder when floor the peddle: pls help
Try a Boost leak test. Seems as if you are getting fuel cut but yet arent seeing the air flow that would create it.
Go to www.vfaq.com and make yourself a boost leak tester and search for leaks. If you dont find any then go on to the next possible cause. Spark plugs/wires like was mentioned before! Good luck.
Originally Posted by S2kracka
Like, check like your like plugs and probably like your plug wires too. More than likely, you need new ones of both.
LMAO... That was well put!
Originally Posted by shoutbox
