Old 06-22-2005   #14
Onefast99gsx
Re: Cam Cap Numbering/Labeling
I just did my cams about 1 month ago after i upgraded to HKS 272's. E1 and I1 start at the timing belt. Each cam cap is labeled. If you position the head so the cam sensor side is towards you and the timing belt side away from you, the cam caps would go on so you could read the E1, E2, E3, etc.. in that way. If you got the timing belt side towards you and you can read the cam caps, then you have them on the wrong way. If you got them on the right way that i say, the arrows will be pointing the right direction.
