Old 06-25-2005   #3
Re: What Gear oil do you use?
Notchiness comes from lighter fluids, like red line, royal purple, sychromesh, etc. BG is one of the heavier fluids and results in less notchiness, but if your synchro's are already worn, it will cause more grinding. The heavier fluid offers better protection though. It is also fine to mix fluids. 1.5 qts of BG II and 1 qt of redline MTL would probably work great.
