Old 08-04-2005   #5
howslowcanyougo
Older than Dirt...
howslowcanyougo's Avatar
Drives: IX EVO MR/SE
Re: What is a "REAL" boost leak test?
Originally Posted by Alpine TSi
Keep in mind with new hard pipes and a bigger turbo you will actually hear the air moving through the IC/pipes and actual spool up. I remember that when I got my car back from QPR last summer and I thought it was a big ass boost leak but was actually the sound of air moving through 2.5 stainless pipes. Later that season we did a boost leak test and only found one at where I blocked off the PCV fitting on the intake manifold.
Thanks for your input!
If there wasn't a big boost leak "somewhere" I probably shouldn't have a problem with DSMLINK reporting that I'm ok running at a ~18/1 A/F, but when I richen it up to where DSMLINK reports close to 11/1 the car bogs and back fires?
This leads me to believe that the Mas is measuring Air that never makes it to the motor, there by giving the symptom of running ok while that lean?
Does this make sense, or am I way off base?
I'm really trying to diagnose the weak power, strange loud noise and weird DSMLINK reading symtoms to get this car back on base?
TIA.....
Let the madness begin...
