Old 08-06-2005   #1
Re: Aftermarket Fuel Line options
Sorry, I meant Aeromotive, not Aeroquip. #12301
Some of those smaller aluminum fuel filters that you might find with -6 fittings on them by companies like Edelbrock, Earls, Russell, etc aren't meant to handle the fuel pressures you might see on a high boost car. If you aren't going to run 30+psi then you might be able to run one of them if you keep your base fuel pressure down at a normal level.
