Old 08-18-2005   #8
rick shindley
Guest
Tournaments Won: 6
Posts: n/a
Re: cam caps torq?
The 2G cas "armature" can be isntalled two ways (right and wrong). The right way is witht he dowel pin (on ohter end of cam) in the "up" position, the CAS armature should have its smaller section topmost. (If you look at the armature you will see that it is not symmetricaly. The smaller part should be "up" when you install it).
I had to draw a damned pic of it above my bench so I wouldn't have to go look it up for the 17th time on the DSM CD!
Rick
