View Poll Results: Where do I go from here? (now that all of the children have grown up...)
Build the X 17 56.67%
No one wants a $60k evo with high monthly payments, get out now and buy a 9. 13 43.33%
Voters: 30. You may not vote on this poll
Old 05-10-2012   #1
I can't think of one at least.
Christening the car with a lady?
Old 05-10-2012   #2
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Car can be off for that, duh.
Unless we want the rumble there for vibrating murlo
Old 05-10-2012   #3
A/C to unsteam the windows son!!! Or heater if it's too cold for little Murlo
I do like the vibrations idea though, poly mounts FTW in this case.
Old 05-10-2012   #4
Murlo26
Murlo26's Avatar
Steam = privacy that with my tint and its a no peep show venue. LOL @ heater.
Indeed, poly mounts!
Old 05-10-2012   #5
Turn off the o2 sensor and run it open loop. No fuel trims anymore... Your big MAF is going to make the car more inconsistant and have bigger swings than a stock sized MAF car with stock injectors.
Old 05-10-2012   #6
Murlo26
Murlo26's Avatar
I am on the stock intake/MAF though right now. So in theory it should run fine correct? Assuming injectors are decent and not piles of crap?
Maybe I could just run open loop instead...hmmm, who knows. I am about 2 steps from ordering the 2150's and being done with it and just running open loop. I have talked with several people and on E85 people seem to get the 2150's to work perfectly fine.
Old 05-10-2012   #7
Do you feel the car bucking or something?
Old 05-10-2012   #8
Murlo26
Murlo26's Avatar
Not really, once I put my stock MAF back on to try and tune the DW injectors, regardless of the scaling/latency the car has felt super smooth.
I am just trying to get my trims to stay somewhere normal.
Old 05-10-2012   #9
Get the 2150s and be done with it, plus we know you are going to go bigger.
Old 05-10-2012   #10
I love my High-Z FIC's (similar to ID1000's). Pretty much a High-Z fanboi now. 1000's or 2150's is probably all I will ever run.
Old 05-11-2012   #11
Murlo26
Murlo26's Avatar
Yea I have heard very good things about the FIC 2150's. All the guys I talked to said no surprises tuning them and on E85 they drive pretty damn good.
So I might order these today, we will see if the mood strikes me right.
Old 05-11-2012   #12
Murlo26
Murlo26's Avatar
So it looks like a few people have suggested I may have a leak pre O2 sensor causing my issues.
Does anyone have stock X injectors I can borrow for a few days?
Old 05-11-2012   #13
Is anyone running 2150's on the stock X ecu successfully yet? I thought about putting them in my car but didn't wanna mess with them at the time...I'm sure someone has done it by now (and hopefully shared their results).
Old 05-11-2012   #14
Murlo26
Murlo26's Avatar
Yea, plenty of people. On pump gas they aren't really recommended. But I just spoke with Golden and he has tuned two on E85 on the 2150's and he said they idle fine at like 800rpms and drive perfect.
You don't have your stock injectors do you by chance?
Old 05-11-2012   #15
I do...can mail tonight if it's important.
Old 05-11-2012   #16
Murlo26
Murlo26's Avatar
Shawn has some too, so if I do end up needing them I will PM you
Thanks a ton for the offer though, much appreciated.
I am going to stop at MAP here shortly and put the car on the lift there over my lunch break.
From the logs it looks like an exhaust leak or possibly a boost leak. So I will see if we see an exhaust leak or try and do a quick boost leak test.
hopefully we find something. My scalings for the injectors are currently overly rich by quite a bit, down to 636 and at cruise the car is still adding fuel, so it would seem there is a leak.
Old 05-11-2012   #17
I usually run the 2150s in open loop, because the "small" swings that factory ECUs do around stoich during closed loop are huge swings with the 2150s. They tune amazing with standalones, you have to put up with some quirks on stock ECUs, since stock ECUs often don't work the best at very low pulse widths.
Old 05-11-2012   #18
Nope I do not. Would love to see what all he did to get them to run nicely, as I'm sure there's some tweaks that are needed (esp per shane below)
I wonder if there's a way to narrow that 'sweep' that's made during closed loop....I'll talk to tephra & mrfred.
Old 05-11-2012   #19
Murlo26
Murlo26's Avatar
If you want, PM me and I can give you his email if you want to ask him a few things. I am not sure of all the details, but he didn't seem to have a problem dialing them in. I assume open loop for sure.
Or you can try a PM on EvoM or Evoxforums, name is Golden.
Old 05-15-2012   #20
Murlo26
Murlo26's Avatar
http://www.youtube.com/watch?v=8IoJ5eR0HWs&hd=1
Tested it out knoxville's G8. Looks great, just wind noise! His car sounds nice though regardless.
Tags
casual mention of an evo, cold little murlo, daves sexcapades, flip flop, flip flopppp, hotdog crank polishing, manifold butthurt?, sexy time.
