Old 08-23-2004   #1
john
Business as usual
john's Avatar
I finished installing a 2600 clutch, Fidanza flywheel, new OEM TO bearing, a QPR longer slave rod and I cannot get the tranny into gear. The pedal seems to run into the floor but I cannot select gears. This is similar to what Kougar had a while ago in his quest. Could the longer rod throw off the shift fork movement? Do I need to adjust the clutch pedal? I know it was right before. Seems that the pedal has a bit of play before it grabs and becomes firm. Please tell me I do not need to take it apart again hmy: .
What do you think is wrong? This is my first clutch swap. Please help ASAP. Thanks in advance, John.
97 Viper GTS
