Old 06-18-2009   #181
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Re: Getting the Laser ready for AutoX
damn...i envy your engine bay so much. makes me want to clean my engine bay! lol. looking freakin good though man. hope to see it at the cookout!
ლ(ಠ益ಠლ)
Old 06-18-2009   #182
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Thanks! I plan to be there. Maybe even rock falls. I just hope twack can get his car on the road so I have someone to drive with.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 06-18-2009   #183
twack
It was a auto get over it
twack's Avatar
O snap! called out! haha i take that challenge
Old 06-18-2009   #184
Wow, I totally missed this thread. Damn clean car man, I'm lookin forward to see more progress!!
Old 06-18-2009   #185
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Lookin good! Can't wait to start cleaning mine up some more.
-1990 Mitsubishi Cyborg 4WD-
Old 06-19-2009   #186
123abc
123abc's Avatar
Drives: Loud cars
Thanks guys!
Andy, what are you going to do to yours now?
Travis, I think you should just bite the bullet and convert to a manual setup.
Old 06-20-2009   #187
123abc
123abc's Avatar
Drives: Loud cars
Me and my dad finished up the wiring harness. I also got most of it installed, just need to do a few modifications to make it work. Took a few pics:
Here you can see where I mounted the injector resistor box, and the defroster relay along with the other diagnostic plugs for setting/checking timing, fuel pump, etc. I'm also mounting the fuse block that usually sits on the positive battery post into the glove box:
Here is the new clutch disc:
Old 06-20-2009   #188
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
I'm likin the clutch disk! My plans are to redue the whole wiring harness and take out everything that I don't need. Then re-run it through the bottom center of the fire wall. I'm gonna try and hide ALL the wires. But we'll see what happens..
Old 06-21-2009   #189
123abc
123abc's Avatar
Drives: Loud cars
Good luck man. I was originally going to run them through a custom hole right under where the shifter cables go through the firewall but obviously I decided not to. It's quite the pain in the ass un-wrapping the harness but once you get going on it, it's pretty simple. Just man hours.
Old 06-21-2009   #190
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Yeah it takes a lot of patience, but my car doesn't get driven all that often and not in the winter. So that should give me enough down time to get it all done. When do you plan on having you're car finished?
Old 06-21-2009   #191
123abc
123abc's Avatar
Drives: Loud cars
It'll never be finished, however I hope to be driving it in the next few weeks.
Old 06-21-2009   #192
123abc
123abc's Avatar
Drives: Loud cars
Clutch is in and torqued to 16 ft. lbs., 95% of the wiring is done, turbo is on, and the oil pan is off. I can't believe how thin that oil pan gasket is. I was expecting a cork gasket or something, not what looks like paper thin material.
Tomorrow the transmission goes in. I hope everything goes good.
Old 06-24-2009   #193
123abc
123abc's Avatar
Drives: Loud cars
Well I picked the hottest day ever (monday) to put the transmission put in, but I got it done with the help of my local friend Carl. It didn't go too bad honestly. Carl said this was about 3 times easier than an awd tranny. I just hope this tranny won't leak.
I really hope this turbo lasts till the end of this year at least. It's not a big deal if it pukes early, I still have my 14b I can just swap into the hotside.
I get paid today so I'll be able to pick up a few gaskets I need and start to make some more progress. Still have some wiring to do, but it's all simple stuff.
Old 06-27-2009   #194
123abc
123abc's Avatar
Drives: Loud cars
Got some more done today. Wiring is done. Intake mani is on. Waiting on a tb gasket to arrive monday. Mostly waiting on my shit to get back from sand-blasting. The guy is doing it for nothing so I'm not going to be one to rush. As of right now, things look good to make it to the up coming winona autoX in a week or 2.
I tried out all the lights and everything seems to be squared away with my wiring. I just hope the engine fires up and has no issues.
Pics:
Here is where I put the chassis fuse box:
I have the fuse box bolted down as of now, the pic was a bit early. I also got the MAF-T in there, I just have to extend the harness for the sensor:
I'm getting very excited to hear it start up for the first time in a few months.
Old 06-28-2009   #195
123abc
123abc's Avatar
Drives: Loud cars
Man, I'm like a multi post whore here! lol
Rolled it outside today for some pictures. Oil pan is on and torqued down, along with the turbo oil return line. The only things keeping me from starting it in fluids, water pipe, i/c pipes and 3 wires that need to be extended and ran to the gm mafs.
And yes Travis and Carl, I am still using my coffee mug/oil catch can!
The stray wire is the positive wire for the fan that just needs to be tied into that fuse block.
I bled the clutch but the pedal seems really light. Is there any other things besides bleeding it at the nipple on the slave?
Old 06-28-2009   #196
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Nice location for the fuse box
Old 06-28-2009   #197
123abc
123abc's Avatar
Drives: Loud cars
Why thankyou sir. You should post a pic of yours so I can see how yours is mounted.
Old 06-28-2009   #198
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Here's a pic. You can see a little 90 degree bracket I made and then the other mounting tab just lined right up with an existing hole.
Old 06-28-2009   #199
123abc
123abc's Avatar
Drives: Loud cars
Nice. Little bit cleaner than mine. You're going to have your talon at the cookout, right?
Old 06-28-2009   #200
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Nah I'll be down here in IL so I wont be able to make it..
