Old 11-29-2010   #181
Re: Project Lex
ECU notes for myself:
http://mkiv.co.uk/vbb/showthread.php...-Harness-Clone
Old 11-29-2010   #182
Re: Project Lex
Just ordered up a couple more things from MAP. Great prices thanks Chris!
Pro Sport Boost Gauge (30-0-30):
http://www.maperformance.com/prospor...rformance.html
Depo Wideband Gauge/kit. Helluva price, never seen a WBO2 kit (w/ gauge) for this cheap before. And the gauge is a perfect match to the Pro Sports :
http://www.maperformance.com/depo-ra...-52772led.html
Old 11-29-2010   #183
DoughtCom
It's deluxe son... deluxe
DoughtCom's Avatar
Drives: Your mom
Re: Project Lex
WOW that's a great price on that wideband. I'll have to keep that in mind.
2010 Evo X GSR
1997 Subaru GC8 STi
Old 11-29-2010   #184
Re: Project Lex
Aren't you going to max out that boost guage
Old 11-29-2010   #185
Re: Project Lex
Good price indeed, although an AEM is only 10 bucks more now-a-days.
http://www.maperformance.com/aem-ana...-30-5130w.html
Old 11-29-2010   #186
Re: Project Lex
Yup, but on the Depo one, the gauge is the same as the Prosport, which is why I chose that. I'd like to keep all my external gauges as similar looking as possible, rather than having a hodge podge of different brands like I had in my Talon (SW, Greddy, Autometer, PLX...). Trying to keep it as clean looking as possible
Old 11-29-2010   #187
Re: Project Lex
Ha, yeah I hear ya. I actually spent a bit of time trying to figure out what to do because ideally I'd want a gauge that goes to 35 or 40psi. Problem is, I wanted to keep my gauges as similar as possible. So I didn't want to end up with another 40psi Stewart Warner, with some other brand WB, and a different brand EGT, and some other brand Oil Pressure. And I didn't want one that is boost only (no vacuum), so finding one greater than 30psi that also shows vacuum, with other matching gauges was hard. So I just settled on this as I will have a loggable MAP sensor in Megasquirt which will tell me my boost above 30psi. And I'm thinking since the gauge is mechanical, that if I go beyond 30, the needle will continue to wrap around. So I can see 35psi on the MAP sensor, and look at the gauge and just note to myself that "35 is when the needle is on the 's' in boost" or something, so I can still kinda know what's going on there I don't ever really plan to go much beyond 35psi. If that day comes, well then that may be the day I decide to go with a different boost gauge. But I forsee this one being just fine for me in the end
Old 11-29-2010   #188
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Project Lex
Great gauge, I've got the Amber version in my car. The thing I'll note is that you don't want to use the included tee, it's got a restrictor outlet that severely cuts down the responsiveness and accuracy of the gauge.
Originally Posted by Trogdor
Old 11-29-2010   #189
Re: Project Lex
Noted, thanks
Old 11-29-2010   #190
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Project Lex
I run 37psi on my 30psi gauge, works out great, lol, just pegs at 30 the whole time.
I am in the same boat though, can't decide what to do for a gauge that reads up to 40-45psi and a matching AFR one to go with it...someday I will get around to buying that stuff.
AEM maybe? It's one I am considering, I think their gauge goes up to 35psi or one of theirs does.
Old 11-29-2010   #191
Re: Project Lex
Is yours mechanical or electronic? The one I got is mechanical, so I'm hoping the needle continues to sweep past 30psi, and doesn't just peg at 30.
Old 11-29-2010   #192
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Project Lex
You could consider wiring in one of the Evoscan NAV displays. It'd read your MAP sensor for voltage and you'd do the conversion.
http://www.evoscan.com/gpsnav
Old 11-29-2010   #193
Murlo26
Murlo26's Avatar
Re: Project Lex
Mine is electrical which is why it stops at 30...the mechanical one keeps going, at least Jakes did in his evo.
The evoscan thing seems unnecessary.
Old 11-29-2010   #194
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Project Lex
This entire hobby is unnecessary.
Old 11-29-2010   #195
Re: Project Lex
Maybe the Evo X talk in the SC300 project thread is unnecessary? lol
jus sayin'
Touche, didn't really think of that.
Old 11-29-2010   #196
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Project Lex
Same reason I got all amber Prosport gauges for the Evo, that way they match each other as well as the gauge cluster. Cleanliness is like godliness, and godliness is, well, what we Mitsu (and ex-Mitsu) owners do best.
Old 11-29-2010   #197
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: Project Lex
35psi in the 2jz holy schnauzer what HP are you shooting for?
Amsoil Dealer
Old 11-30-2010   #198
Re: Project Lex
I have a couple goals. Goal one is to just have this running decently on WG pressure this upcoming summer. And at that I hope to be in the 350-400 range. Then the following summer (when I have money and time to upgrade the drivetrain) I hope to turn it up to around 35psi and get 600-650 out of it. Then will probably turn it down to 30 or so for a safe street tune.
I think both those goals are very achievable, especially in the hands of Shane on the dyno He's magical!
Old 11-30-2010   #199
Re: Project Lex
OK so like it was pointed out earlier, I got the wrong WG for my manifold. It appears mine is flanged for a 50mm HKS wastegate from what I've been told.
My question now is, from what I've read the HKS 50mm gate is supposed to have a firing ting that is built into the flange. But my manifold flange does not have that. So WTF? Stupid Chinese maybe? I'm about ready to say screw that flange and cut it off and have someone weld on a flange for a Tial.
Here's a picture showing the firing ring built into the flange that I thought this is stupposed to have:
Old 11-30-2010   #200
Re: Project Lex
That fire ring piece does not get welded to anything, it just gets put in between the manifold flange and the wastegate.
It shouldn't take anywhere near 35psi to reach 600whp, unless your turbo or the rest of the setup really sucks. You can reach 600whp with a 4 cylinder with less than 35psi.
