Old 04-16-2012   #181
Revobasher
Revobasher's Avatar
Drives: 14 Evo X GSR
Re: MitsuStyle Spring 2012 cruise - April 21-22, 2012 - Ashland, WI
I hope my car is back from auto body shop by fri. It's not looking good though.
2014 CB Evo X GSR - 323/324 @ 26lbs (Mustang Dyno)
2012 IS250 F Sport - TOTALLED
2006 Evo IX MR - ​SOLD
Revobasher is offline   Reply With Quote
Old 04-16-2012   #182
Better take the cruze!!
Old 04-16-2012   #183
They got snow on the north shore, but I can't see any way there could be any left on Saturday. Hell, it will probably be gone tomorrow.
Old 04-16-2012   #184
Tachyon
Tachyon's Avatar
Drives: Icarus
Got a decent amount done in the last couple of days:
  • Finished replacing 100% of the bushings in the rear subframe, including mustache bushings
  • Added active toe eliminator from s1ngletracker (perfect fit, btw)
  • Added a RM rear sway bar
  • Added poly bushings to the front sway bar (this was a bitch)
  • Installed Ingalls adjustable upper control arms
  • Installed new clutch (went with 6 puck unsprung over 4 puck this time)
  • Replaced the power steering rack with Kevin/Mondale's low mile unit -added new end links
  • Re-installed engine and transmission
  • Fabbed new intercooler pipes for short route to clear my whale penis intake pipe
  • Fixed my propeller shaft (it met a train track in Minneapolis last fall)
All that's left is to add fluids and toss the suspension back on and I am read to rock the casbah.
I'd like to note, I am bit apprehensive driving this new setup as I am used to employing fairly strong amounts of trail braking to initiate rotation on corner entry. I suspect I am going to over rotate a few times getting use to the new setup
-Sebastian Vettel
Old 04-17-2012   #185
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
My backup car is coming now...06 vette...better than nothing, trying to be like asshanson! Snow and a convertible, awesome.
Old 04-17-2012   #186
Mark Leasure
Mark Leasure's Avatar
Why the back up car?
Old 04-17-2012   #187
Murlo26
Murlo26's Avatar
Evo did what Evo does...break. CMC is leaking internally again I believe, lots o air in the system.
Old 04-17-2012   #188
Map packets have been created
Old 04-17-2012   #189
Tachyon
Tachyon's Avatar
Drives: Icarus
Oooh! Has the official beer mug clip-art been used?
-Sebastian Vettel
Old 04-17-2012   #190
Wouldn't be a 'Style cruise without it
Old 04-17-2012   #191
Murlo26
Murlo26's Avatar
So glad I took Friday/Monday off around the cruise!
I am guessing the extra day of recovery will be most needed haha.
Old 04-17-2012   #192
Haha nice, almost as many vettes as DSMs going now! Yea I was kind of worried about it being cold up there still, will be lots of tire spinning I guess.
Old 04-17-2012   #193
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Yes we will be party rocking!
Actually, i lied, hang around the drinking league if you want to party hard.
PlanoEvo is offline   Reply With Quote
Old 04-17-2012   #194
*E85 ALERT*
E85 stations may be a problem! Calling around to stations listed online as having E85...turns out they do NOT. We can not guarantee E85 stations will be available between the meeting spot and Duluth Sunday morning on the trek home. What this means is you MUST carry enough E85 to go 315 miles, assuming you arrive at the Saturday morning meeting spot fully topped off. Scheides plans to carry 10 gallons in his trunk which will be more than plenty for him, but please be conservative when doing the math and make sure you have enough. We may encounter some stations along the way, but I can NOT guarantee it.
Here is an E85 station right next to the meeting spot:
Store 306
4167 Ball Rd NE
Blaine, MN, 55449
Phone: 763-785-4237
You MUST arrive by 9am SHARP fully topped off, do not arrive then expect us to wait around while you go fill up.
Old 04-17-2012   #195
Tachyon
Tachyon's Avatar
Drives: Icarus
I also did some phone checking and it looks like Kracka is correct. The Cenex in Ashland use to, but discontinued it due to little demand.
It looks like the closest place is Superior WI, which is about 65 miles away.
I will bring 10 gallons as well of which I'll need 4 of them to get to Superior.
-Sebastian Vettel
Old 04-17-2012   #196
Mark Leasure
I can drive to TX and back on E85. What's the route? 35 up to Duluth? Then over to Ashland? I don’t plan on bringing enough e85 for 300+ miles. Fuck that. A little more research is required, I drove to Ely this Jan on corn. Hopefully not too many stations quit selling it.
Old 04-17-2012   #197
Mark Leasure
E85 verified in stock at:
Holiday Stationstore
9314 West Skyline Parkway, Proctor, MN
It’s the spirit mountain exit.
I need to plan 1 more stop around Hinckley and we should be good it that’s the route there.
Old 04-17-2012   #198
Murlo26
Murlo26's Avatar
Typically the route is backroads as those are the "fun" roads. That being said I have no idea how we are going about getting there.
Old 04-17-2012   #199
Mark Leasure
I didn't realize that it’s only 143 miles between E85 in Blane and E85 in Duluth on 35, easy. No problem. I'm going to bring 10 gallons as well in the event of other routes home or getting there.
Old 04-17-2012   #200
We're working on a solution guys...hope for the best, plan for the worst. Lunch is in Hayward, that will give you a general idea of the route we're taking. If someone is willing to assist in the mapping of E85 locations please PM me and I'll get you the exact route.
