Build the X 17 56.67%
Old 05-04-2012   #1
93gtpeater
Drives: cbr 1000rr repsol
Glad to see its drivable again. Hope it makes it the rest of the year without anymore problems.
Old 05-04-2012   #2
X2.
Now get out there and let me spot you guys! I'll be in the scary looking honda.
Old 05-09-2012   #3
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
GoPro hero2 comes today!
I so badly wanted to not buy it as there are other car mods to buy yet and money for fixing shit lol, but I needed one at some point.
I'll get some test vids up later.
Old 05-09-2012   #4
Needed one?
Old 05-09-2012   #5
Murlo26
Murlo26's Avatar
Needed one?
Ok, well just really wanted. But I plan to use it at proving grounds and other fun times!
Need in my mind though
Old 05-09-2012   #6
Old 05-10-2012   #7
Murlo26
Murlo26's Avatar
Well I was busy last night doing logging and forgot the gopro needed to be charged, I will try and test it out tonight for fun.
I came to a realization though, I know why tuners hate DW injectors!!!! Because they suck to tune lol.
I am on revision 8 now for scaling/latencies and have done ~45 minutes of logging for each, that is over 5 hours of scaling lol. Still not dialed in yet. Ugh. I remember why I pay people for this shit, but I am learning a lot. I will get my trims under +/- 5% yet! The best I have seen so far on these is +/- 8%.
Old 05-10-2012   #8
I have 0 problems with my DW 1000's in my AEM car
Old 05-10-2012   #9
How are you still screwing around with your injectors? I thought they were set?
Buy some FIC 1680's man, they're not as bad as everyone says
Old 05-10-2012   #10
Murlo26
Murlo26's Avatar
I have no idea, they suck, lol. They just seem very very inconsistent. I have done tons of logging and just when you start to think you are getting close they wonder around for trims like crazy.
I am running my stock intake duct taped in there basically right now so I am on stock MAF scaling to try and get the injectors perfect.
Maybe I should just upgrade to the 1680's. So you haven't seen any problems on them? Did you have to do any minIPW shit? And they run pump gas well enough to put a tank through every once in a while?
Old 05-10-2012   #11
Yes I had to drop minIPW but it was a single, simple change and no issues since then. They ran like crap w/o that change.
They run great on pump gas.
The scaling/latancies I'm using are from mrfred...shane kinda hates them b/c the car does some goofy shit but end of the day it starts every time just fine (just fixed hot start issue this week actually, but that was minor), and the car drives good and smooth. AFRs are very consistent on the street.
Old 05-10-2012   #12
Reading this makes me love my ID1000's even more...you would never, ever, know they're anything but stock (idle, drivability, start-up, etc.)
Does ID make anything between their 1k's and 2k's?
Old 05-10-2012   #13
Murlo26
Murlo26's Avatar
Hmmm, well I emailed MAP to see if they have any in stock. If they do maybe I will impulse buy them and dump my DW's.
Kracka, if ID made anything close to what I need, even 1200's would probably work, I'd run those all day long. But nope, just 1k to 2k for them and I don't want to deal with the 2000's on stock ECU, they can work well but it takes a lot of work. And frankly I want to beat on my car some! I haven't gone WOT in months now.
I also have to swap in my hobbs switch to get rid of the blaq box I have. I don't care for it and I think it just complicates things and I don't see an advantage.
Old 05-10-2012   #14
Are you sure the ID1k's wouldn't work for you? They're rated conservatively and I'm probably around only 50-60% IDC right now.
Old 05-10-2012   #15
There's no way those would be enough on his car. ID was going to make 1500's, same as my FIC 1680's but they got the plug pulled on them for some reason.
Old 05-10-2012   #16
Probably that.
Old 05-10-2012   #17
Murlo26
Murlo26's Avatar
Pretty sure. I was over 100% duty cycle on my DW1000's on my FPred setup at a lot less power. At least I think I was. 420whp vs. 500whp on DB's dyno.
I wouldn't buy anything smaller, mine work, just not great. And I don't want to spend money unless its a for sure thing.
Old 05-10-2012   #18
Murlo26
Murlo26's Avatar
ID had 1600's out for quite a while actually. They pulled there injectors first (they were based on the same injector as the FIC 1680's).
FIC did their own testing and still have the 1680's but they are strictly E85 rated only due to the fuel temp issues.
Old 05-10-2012   #19
Ya, just don't let your car sit and idle for 40 minutes at a time :P
Old 05-10-2012   #20
Murlo26
Murlo26's Avatar
I would never idle the car longer than 20 mins for any reason honestly. I can't think of one at least.
Tags
