Old 06-02-2011   #201
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: GsXtUrBo98's 2G project thread
Well..... I did a boost leak test and had a MASSIVE BOOST LEAK ( wont hold more then 1lb of pressure.. ) where I believed to be between the SMIM and head so I took all that shit apart and put some black rtv on both sides of my plastic gasket. Well, after putting it all back together I did the leak test again just to find out that it was actually my Injector O-Ring..... So I'm headed up to Primo to get some new ones and try it again.. I'll keep you guys updated.
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 06-02-2011   #202
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Once it warms up I should be good though right? Or do I have to worry about this all the time?
figure out a way to get that iacv hooked back up! There are more then a hand full of people my self included that have done the same thing that you did and all say it sucks. its not robbing you of any power so get it back on there.
Amsoil Dealer
Old 06-02-2011   #203
GsXtUrBo98
GsXtUrBo98's Avatar
^Negative. On a side note I got my injectors sealed up and ready to go. I have some leakage from the tb seals... When I got it all hooked back up I went to start it and the battery was dead...... Well, I'm going to bring my battery to work tomorrow for charging and then see what happens after I throw it back in.
98 GSX (built)
03 BBY EVO dd
Old 06-02-2011   #204
95talonracer
Finally Tuned...
Drives: Spyder GSX
Is there a positive you see to not putting it in besides not taking a few minutes to get it to go back in? It isnt hurting your power at all so why not have it run better? If you ae using a dsm TB then why not hook it up? I can see if you had a q45 or something.
Amsoil Dealer
Old 06-02-2011   #205
GsXtUrBo98
GsXtUrBo98's Avatar
It clears up space. Those coolent nipples catch on my fuel line and I don't like the clutter
98 GSX (built)
03 BBY EVO dd
Old 06-03-2011   #206
Car that runs nicely > Pretty engine bay IMO
Old 06-03-2011   #207
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
This is a very nice car, youve made amazing progress on it as well. Its very inspiring, and a real motivator to continue the visual aspect of my project instead of just focusing on the performance. Turning and stopping fast is just as fun as straight line speed.
Old 06-03-2011   #208
GsXtUrBo98
GsXtUrBo98's Avatar
Thank you, its nice to see my car making other people feel good because this car is stress and sometimes I don't think I can motivate myself anymore but somehow I keep truckin.
98 GSX (built)
03 BBY EVO dd
Old 06-03-2011   #209
95talonracer
Finally Tuned...
Drives: Spyder GSX
X2 now put it nack on there and quit being a typical dsm'r. I had mine on and I never once had anyone say anything about it being there and you can barely see it.
Amsoil Dealer
Old 06-03-2011   #210
GsXtUrBo98
GsXtUrBo98's Avatar
I don't care that its there.. If it becomes an issue down the road it wouldnt take much to put it back in.. JEEZ you would think this is your car...
98 GSX (built)
03 BBY EVO dd
Old 06-03-2011   #211
95talonracer
Finally Tuned...
Drives: Spyder GSX
I want a ride in it so get it on the road!
Amsoil Dealer
Old 06-05-2011   #212
GsXtUrBo98
GsXtUrBo98's Avatar
I installed the head lights, tail lights, and reverse lights today. Also, put on the exhaust that I dont want to run but need an exhaust on there for the time being, then I took the car for a little ride around the block and the clutch needs adjusting pretty bad, It inguages almost at the floor.... Anyways I'll get some pics up soon and maybe a video? we'll see.
98 GSX (built)
03 BBY EVO dd
Old 06-05-2011   #213
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
good work! Why'd you call though?
Old 06-05-2011   #214
GsXtUrBo98
GsXtUrBo98's Avatar
I'm having clutch engagement issues and have been putsing with it for hours and have no idea what the hell to do... I can rev it up and my car will move with the clutch at the floor.. I watched a jacks video on how to adjust it but no matter what I do it doesn't change. I'm at a loss......
98 GSX (built)
03 BBY EVO dd
Old 06-05-2011   #215
Did you torque the pressure plate properly? which clutch is it? standard single discs will drag at somewhere above 7k rpm usually no matter what, is that what you're experiencing?
Old 06-05-2011   #216
GsXtUrBo98
GsXtUrBo98's Avatar
Its a ACT2900 and it was all torqued to spec, its engageing at the floor and yes it is draging at high rpms... jacks says you shouldn't have any drag though..... I'm just frustrated to my limit right now...
98 GSX (built)
03 BBY EVO dd
Old 06-05-2011   #217
95talonracer
Finally Tuned...
Drives: Spyder GSX
Come on man its a DSM you have to have ALOT of patients otherwise sell it because they will do that to you. You do have that longer rod in the slave cylinder right?
Amsoil Dealer
Old 06-05-2011   #218
GsXtUrBo98
GsXtUrBo98's Avatar
I have the longer rod in there. I won't give up on it but its not helping that I wanted this thing done by brainerd.. if it keeps going this way I won't be making it out there..
98 GSX (built)
03 BBY EVO dd
Old 06-05-2011   #219
b00sted_spyder
Did you properly bleed the clutch?
Old 06-05-2011   #220
GsXtUrBo98
GsXtUrBo98's Avatar
Yes, twice
98 GSX (built)
03 BBY EVO dd
