Old 09-16-2010   #201
Re: Project S14 240sx
302 is almost equal to our motors for the cheapness. replace the pistons then boost away.
Old 09-16-2010   #202
Originally Posted by Andrew7dg View Post
the 302 engines are very plentiful, tons of aftermarket support for them, and if it is an easy swap GO FOR IT! Just make sure that you find a manual trans for it instead of going automatic.
That's exactly the reason I decided on a 302. And yes, I plan on going with a manual trans, I just have to figure out a way to adapt the cable clutch to my pedal assembly (Stock 240 is hydraulic)
Are you going to keep the AC?
Power steering?
A/C has been removed since before I bought the car, and I'd like to figure out a way to keep the power steering, but if I can't mount the pump it's not really a huge loss.
After it is all done, you could then take it to car craft where it would have a little more respect
BTW, even though it is fun to build your own motor, don't over look the possibility of buying one that is already built and has been slightly used. 302 race engines are very plentiful and cheap. 8 built rods for 5.0L are cheaper then 4 rods for a 4g63. Also I would see if you could stay fuel injected so that it is a little more DD. not that carbs are bad but you will get better fuel economy, cold start, driveability with Fuel injection.
I've been keeping my eyes open for a good deal on a race engine since that would save me a lot of time and money. I'm planning on going with a carb initially just cuz they are so easy to deal with, and it will get the car back on the road faster. If I decide down the road that I want to boost it, it would be easy enough to find a fuel injection setup for it.
Old 09-16-2010   #203
Whoah, big change! If it happens you will lose your jdm drift king rep! It'll be sweet either way.
Old 09-16-2010   #204
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
I say go for it! Get one built for some boost and flip the manifolds to mount a single up front.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 09-17-2010   #205
get a ford mod motor 5.4 or a 4.6 lol. Don't know if it'll fit.
Old 09-17-2010   #206
^ They won't. The heads are way too wide to fit between the strut towers.
And Scheides, there's nothing JDM about my car right now, other than the S15 diff, and the fact it was assembled in Japan. haha
Old 09-18-2010   #207
I think it would drift even easier with more TQ at hand.
Old 09-18-2010   #208
I agree. The back end should step out very easily with ~400wtq and no turbo lag.
Old 09-18-2010   #209
you need to run caigs fiero when you get the 302 in
Old 09-18-2010   #210
Is the fiero faster than the hemi?
Old 09-18-2010   #211
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
need to finish getting it in tune, but then it should be same horse power as the 300 but half the weight.
Old 10-02-2010   #212
So I tried fitting my snow tires/wheels today and ran into a problem... The barrel of the wheel hits the front calipers, so I need to get some 300zx rotors instead of the 350z rotors to make a little more clearance.
Old 10-03-2010   #213
D_Venable
SQ addict
Drives: 85 and 88 Conquest (plus a 2011 Silverado)
Send a message via AIM to D_Venable
being a Mitsu forum, I find this to be somewhat useful info....
iirc, the 3000GT VR4 4 piston calipers are identical to the 300zx calipers except for the name on the outside (Mitsu instead of Nissan, both made by Nissin, iirc again)
D_Venable is offline   Reply With Quote
Old 10-03-2010   #214
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
i have a buddy with a 96 s14 with a 406 small block with a single gt30r, he was having issues tuning it and took of the turbo and still runs 11's...
Originally Posted by 311evo
Old 10-05-2010   #215
The 300zx caliper is made by Sumitomo (cast right into it, just below the Nissan logo) and the reason the calipers don't clear the wheels is because I'm running 350Z Brembo rotors, so the caliper is spaced farther out than it would be if I had the 300xz rotors. There is a little ridge in the barrel of the 3/S wheels that hits the caliper, so the backspacing isn't the issue.
