Build the X 17 56.67%
Old 06-12-2012   #2201
But you guys are internet racers, you have to at least have a chance on paper to be happy.
Old 06-12-2012   #2202
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
I drive my car more than you do
So boom.
Old 06-13-2012   #2203
Murlo26
Murlo26's Avatar
Silly VD numbers...but 500whp on 93 at 24psi...yea...sweet...
Old 06-13-2012   #2204
So boom.
HAHAHA ...and owned!
Old 06-13-2012   #2205
So boom.
Just this year you have so don't get too excited.
But for you that just means you are closer to:
Old 06-13-2012   #2206
93gtpeater
Drives: cbr 1000rr repsol
Haha. Hope it makes it to pg this year.
Old 06-14-2012   #2207
Murlo26
Murlo26's Avatar
So, battling fuel pressure problems right now. My AEM is adjusted for max fuel pressure and it won't go above 42ish at idle.
So as I believe Shane suspected, the car appears to be bleeding fuel back through the second pump. Doing some testing now, but might be getting a check valve for the second pump soon.
Need to bump fuel pressure so we can reduce load as I was hitting 330load and boost cut (319 load) on pump gas at like 24psi.
So we are making it so the load is hopefully 270ish around there by changing around a lot of stuff. (injector scaling, MAF/MAp tables etc)
Not going to lie, I doubt I am going to PG. Especially since work is really crazy. I am kinda bummed but frankly I don't want to go until the car is working fully. I will head out to RF or BIR at a test and tune day when its done if I don't make it.
Still going to try and make it but not looking good now.
Old 06-14-2012   #2208
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
You have 8 days left, that's plenty of time.
Old 06-14-2012   #2209
simulatedwood
Drives: 08 Evolution X
I am going to make you a liar! Your coming to PG, that thing is going down the track if we have to push it!
Plus..Don't think of the PG as just a event, think of it as a 3-day Mitsustyle cruise, with lots of nightly festivities, and driving with a hangover. 2 things we are good at.
Old 06-14-2012   #2210
Tachyon
Tachyon's Avatar
Drives: Icarus
I'll help with the pushing!
Seriously, you need to just force yourself to have realistic goals, then focus on having fun, even if it's not at 10/10ths level.
Heck, I only managed to get about 60% of the things I wanted to do done on my heap before the PG, but that's not going to stop me from enjoying what a brought to the fullest!
Having slightly reduced fun > no fun.
-Sebastian Vettel
Old 06-14-2012   #2211
Don't be like Chkmgnt...constant work in progress, then once it's finally done get fed-up and sell it. That's what happens when you don't stop and actually allow yourself to enjoy the car while it's in process.
Old 06-14-2012   #2212
cmspaz
Walls need hugs too
cmspaz's Avatar
LOL! It's so true.
Originally Posted by Trogdor
Old 06-14-2012   #2213
Murlo26
Murlo26's Avatar
It might be just as easy as getting a check valve for the 2nd pump...but I need to pull the pump out sometime to look at it to get an appropriate one.
I am trying to make it, I have been working on it tons lately, like every night for weeks. But I am starting to run out of steam a bit and work is getting really bad. But we shall see, I could always just run pump gas there instead of e85 just to make it there.
Old 06-14-2012   #2214
Tachyon
Tachyon's Avatar
Drives: Icarus
Do it!
Working on cars is no fun when you're allready stressed and rundown... that's how mistakes get made.
-Sebastian Vettel
Old 06-14-2012   #2215
Just run it at lower power, like 350-400, and run the road course instead.
Old 06-14-2012   #2216
Murlo26
Murlo26's Avatar
Hmmm, interesting...I wouldn't mind doing that. But I still need to get my fuel pressure stuff sorted, then its just tuning.
The car/tune is all jacked up as it was looking for a higher base pressure so I need to do that first.
Old 06-14-2012   #2217
t-revzr
FLOSSEN
t-revzr's Avatar
Drives: 2011 corolla turbo S
It's so crazy how much time and money you've put into this car and it still has issues..
T-rev still #1 and lovin it!!!
Old 06-14-2012   #2218
What sort of check valve are you going to use? I have a -6 in/out one way fuel valve that I used on the V when I was having issues with the siphon letting fuel back into the tank.
Looks something like this but a little bigger:
Old 06-14-2012   #2219
Murlo26
Murlo26's Avatar
Not sure yet, I need to pull the backseat and do some measuring. The two pumps meet at a Y outside the tank, so I am thinking of replacing part of the hose with a check valve.
The size I haven't figured out yet.
Old 06-14-2012   #2220
Oh nice, if you have enough room outside the tank that would be a lot easier than trying to fit the check valve inside the tank.
Is the Y fitting AN or barbed?
Tags
