Build the X 17 56.67%
Old 06-19-2012   #2241
Knoxville
Drives: 09 G8 GT
If you get the week of the 4th off, you better be at my Dyno pulls at DB
2009 G8 GT
Knoxville is offline   Reply With Quote
Old 06-19-2012   #2242
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
I'll be there, so I can watch you blow up on the dyno Muhahahahaha.
Update:
Check valve in, of course the main pump was switched from what I expected it to be (it wasn't the stock bulkhead) so changed my design a bit. However it's in and working!
Hard to tell from the last pic, flash reflected off the glass. But over 50psi at idle now Before I had the regulator bottomed out, as in max pressure, wouldn't go above like 42..now it's backed off some and over 50psi...so looks like problem solved!
Oh also picked this up...prolly best $20 ever spent.
No more stupid logging cable in the way of shifting, yay. Back to tuning!
Old 06-20-2012   #2243
Murlo26
Murlo26's Avatar
So I logged the car with ~63ish base fuel pressure and it didn't produce the results we really wanted at all, car was adding fuel all over.
So I am dropping it down to a base pressure of ~50 and we are going to go from there.
On a plus side, the car seems to be quite a bit better when shifting, like no delay, not sure if that is from better fuel pressure but it seems better.
Also, there is a HUGE improvement in starting!!! The car used to take like 3-4 seconds of cranking to start and now I know why, fuel was dumping out the other pump. The car now starts almost instantly, feels great.
Old 06-22-2012   #2244
Murlo26
Murlo26's Avatar
Back to ~50psi base fuel pressure now. Car is driving great again! Nearing the end of the pump gas tune.
However, I apparently run out of gas at 1/4 of tank...lol. Got stuck in a papa murphys parking lot with 1/4 of a tank of gas. I put 3 more gallons in the car after my bro picked me up with a gas jug and it fired right up again. I am going to rework my pump pickup eventually but for now I will keep the gas level high.
However, running into a bit of knock up top that wasn't there before (aka last week). I think its probably from the shitty super america 92 I put in to top the car off. I wasn't near a BP station so I figured I'd put that in for now and then fill the car up at bp...guess that gas really sucks as it appears to be affecting the tune somewhat.
We tried leaning the car out from 11 to 11.5 to see if it was rich knock, helped a bit but still there. I now have 2 maps to try, one with lower timing one with higher to see if those change it. The higher timing is because evo x's for whatever reason tend to act up if you don't give them enough timing...i know last fall the car was even breaking up from too low of timing, then Shane added some and it cleaned up right away.
Car is at ~450whp or so on 22psi with knock so hopefully I can get about 475ish and clean on 22-24psi and then call it good for pump gas then get to the real shit.
More to come.
edit:
here is what the logs look like currently for those who care to check them out. Looking again it just might be too much timing for 93oct on my 10:1 comp, so maybe the lower timing MAP I have will clean it up as the car is perfect until it jumps up a degree in timing.
Green = timing
blue = boost
orange = afr
red (or brown or whatever the hell that is) = knocksum
Old 06-25-2012   #2245
Murlo26
Murlo26's Avatar
Back on Corn...first corn MAP...500whp at 23ish psi...back to the fun zone!
Old 06-25-2012   #2246
Murlo26
Murlo26's Avatar
Starting to have some fun again.
Old 06-28-2012   #2247
Murlo26
Murlo26's Avatar
Anyone have a helmet for sale that is at least snell2005? Or where is the best place to at least go try some on for sizing and possibly buy one. I am hoping to only spend $200 at most. Don't need anything fancy, just something to get this POS down the track finally.
Planning to hit RF the 14th of July...
Old 06-28-2012   #2248
93gtpeater
Drives: cbr 1000rr repsol
If you want to get a motorcycle helmet try a dealership or bobs cycle.
Old 06-28-2012   #2249
You should go on the 15th instead!
Old 06-28-2012   #2250
This is what I have, although I remember paying a bit less for it, closer to $150 shipped? Maybe it was a promo or something...anyways, I highly recommend it Hughes and several others have the same one.
http://www.apexperformance.net/CartGenie/prod-2252.htm
Anyways, you can use mine if you want to try it, esp for sizing. I have a large or XL, I can't remember.
Old 06-28-2012   #2251
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
check out the closeout section on dennis kirk. I got a snell 2005 HJC from them a year or so ago for like $60 bucks.
https://www.denniskirk.com/helmets/1.outlet
Red Joe Rocket snell2005 for $72
https://www.denniskirk.com/joe-rocke...d/3302133L.sku
Old 06-28-2012   #2252
u can use mine if u dont find one in time
Old 06-28-2012   #2253
IIRC I think helmets are generally good for 10 yrs, snell 2000 good to 2010, 05 to '10. Might be worth it to spring for a snell 2010, i swear reading somewhere that a track was only taking '05 and '10. A few years go by quick these days
Old 06-28-2012   #2254
SNELL2005 are good until 2015.
You'll probably want to also make sure it's Snell SA-rated since those are designed for auto racing, not motorcycles. Generally, they're lighter in weight and flame resistant.
Here's what I have:
http://www.pyrotect.com/product.php?...&cat=14&page=1
Here's a whole bunch of other choices though, including some really cheap ones if you're ok with Snell2005 and college logo paint:
http://www.pyrotect.com/home.php?cat...rt_direction=0
Old 06-28-2012   #2255
Tachyon
Tachyon's Avatar
Drives: Icarus
You'll probably want to also make sure it's Snell M-rated since those are designed for auto racing, not motorcycles. Generally, they're lighter in weight and flame resistant.
I think Kracka means is SA rated. M is "Motorcycle"
http://www.smf.org/helmetfaq#aSAMKdiff
-Sebastian Vettel
Old 06-28-2012   #2256
Correct, sorry. Edited my above post.
Old 06-28-2012   #2257
Murlo26
Murlo26's Avatar
Yea I want to go somewhere local to get sizing correct first then I will order online, prolly one of the ones posted
Maybe I will check out the motorcycle place to get sizing right. Then order one up.
Thanks guys.
Old 06-28-2012   #2258
rose0529
rose0529's Avatar
Drives: a red car
Yeah that is what I did as well. Try and try on the correct manf. they vary a little by size
Thanks guys.
Old 06-28-2012   #2259
Murlo26
Murlo26's Avatar
Is there a local place then that has non motorcycle helmets to try the stuff on?
I got a big head so want to make sure it fits nicely
Old 06-28-2012   #2260
I used the measurement chart online for the brand I bought and it worked perfectly. If you're right on the edge between two sizes, go larger.
Tags
